So basically, brand new wiring loom so suit a centre speedo mk3. All indicators work correctly with LED lamps, LED flasher and also flash with the alarm system so everything is as it should be. Now my problem is the tell tail at the top of the speedo doesn’t light up but everything else works at it should do. This has a LED bulb in it also if that makes any difference
Just to note the tell tail has to cables one for left and right indicators
Any help would be appreciated
Edited by jasonmallett, 21 January 2024 - 07:22 PM.
