Loose New Track End On New Rack
10 replies to this topic
#1 jiminwatford
jiminwatford
  • 310 posts
Posted 21 January 2024 - 08:08 PM
I'm in the process of replacing the steering rack and while trial fitting the track road ends before the locking nuts arrive i notice they wobble on the rack. They are genuine item track rod ends
I know the locking nuts are not fitted but do they take up this movement? Seems a bit less than ideal
Video of the wobble:
https://youtu.be/sTOeMt2pufA
Edited by jiminwatford, 21 January 2024 - 08:10 PM.
#2 nicklouse
  • 18,689 posts
Posted 21 January 2024 - 08:17 PM
Did the nuts not come with the rack?
that does look like more than I would like. Something is not to the correct spec.
#3 jiminwatford
jiminwatford
  • 310 posts
Posted 21 January 2024 - 09:06 PM
No the nuts didn't come with it
#4 GraemeC
GraemeC
  • 7,440 posts
Posted 21 January 2024 - 10:11 PM
How far are they screwed on? A couple of turns or lots of turns?
#5 jiminwatford
jiminwatford
  • 310 posts
Posted 21 January 2024 - 11:07 PM
It's about half way on. Similar to where it would be when fitted
#6 bpirie1000
bpirie1000
  • Area Managers
  • 2,373 posts
  • Local Club: Amoc
Posted 22 January 2024 - 02:13 AM
Locking nutt will fix that i am sure. If your worried ptfe tape maybe pack the threads out alittle.
#7 68+86auto
68+86auto
  • 1,005 posts
  • Local Club: Queensland Mini Car Club
Posted 22 January 2024 - 04:07 AM
When you get the nuts see how much they wobble compared to the ends. the ends should wobble less.
#8 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 22 January 2024 - 01:26 PM
I agree with Nick, if that is screwed half way down the thread and it wobbles that much, I would investigate further.
Try one of the old ones on the rack and see if they are tighter
#9 jiminwatford
jiminwatford
  • 310 posts
Posted 25 January 2024 - 01:49 AM
I went to Mini Spares and they're of the opinion that it happens with all Mini track rod ends (basically)
We tried a few different ends and another (genuine) rack and they all wobbled to a broadly similar extent
They said the locking nut should stop the movement. Funnily enough even the locking nut wobbled.
The guy's thought was that they had always been like this and theorised that if they were a better fit they would never come undone (like a modern car he had which needed lots of heat). So they're loose to make it easier to replace.. OK
So i hope they do up tight and don't wobble
I enquired about putting ptfe tape on the thread and he advised not to and said nothing extra should go on there as it may cause more problems
Edited by jiminwatford, 25 January 2024 - 01:52 AM.
#10 68+86auto
68+86auto
  • 1,005 posts
Posted 25 January 2024 - 06:20 AM
PTFE tape won't help.
#11 Spider
  • 15,107 posts
Posted 25 January 2024 - 07:44 AM
Having just looked at your clip, that's normal. They aren't a precision thread. When the lock nut is done up against them to lock them off, they'll be stiff as a board.
