Air Intake Duct Seals
5 replies to this topic
#1 Davidmt
Davidmt
  • 219 posts
Posted 25 January 2024 - 11:05 AM
Having a Mini parts finder morning as it's raining here in York.
I have sourced both the missing air intake ducts for my 1275GT Clubman but neither of the seals.  Obviously they are no longer available at the usual places and therefore looking for either used or alternative parts.
I believe the original parts were CZH711 (on the left) and CZH682 (on the right).
Does anyone have a source of these or recommend alternative products that would be suitable.  I am thinking that any duct seal should work if I get the correct diameter etc?
What has anyone else done?
#2 stuart bowes
stuart bowes
  • 2,290 posts
Posted 25 January 2024 - 11:14 AM
what is it a flat rubber ring or something, I'd probably just order a sheet of rubber material and carefully cut to shape, jobs'a goodun
#3 weef
weef
  • 511 posts
Posted 25 January 2024 - 01:00 PM
Somerford Mini list both the CZH711 and the CZH682 part numbers.
Maybe worth giving them a call  01249 721421.
#4 Davidmt
Davidmt
  • 219 posts
Posted 25 January 2024 - 01:20 PM
Thanks - I did already as they are listed as available for customer order.  They are not!
#5 mab01uk
mab01uk
  • 12,636 posts
Posted 25 January 2024 - 07:32 PM
CatMint do this air hose to bulkhead seal for earlier Minis but not sure of dimensions to compare:-
https://shop.catmint...r-hose-24a2195/
Maybe CatMint could make some if you have old original seals as a pattern?
Edited by mab01uk, 25 January 2024 - 07:34 PM.
#6 Davidmt
Davidmt
  • 219 posts
Posted 25 January 2024 - 07:45 PM
Sadly not - I have ordered some rubber channel edging and some neoprene strip so will make something work!  Thanks.
Edited by Davidmt, 25 January 2024 - 07:45 PM.
