Hi Got a quick question
Im rewiring my 1960 mini. I wanted to check how I would wire the Floor start switch, I assume the negative wire goes from the battery to the first terminal on the floor starter switch, then the power wire from the loom goes to the next terminal along with the negative wire. But does the negative wire from the 2nd terminal go straight to the starter motor?
