97 Rover Mini - Washers Not Working, Fuse Location?
2 replies to this topic
#1 MG99
MG99
    Starting My Mini Up
  • 2 posts
Posted 31 January 2024 - 09:16 AM
Apologies, as this has no doubt been covered on here, but unsure where.
My washers have stopped working, plenty of fluid in the tank but no noise from the motor being made when I try to operate them.
My electrical abilities are limited (to say the least) but thought I'd at least start with the fuse, however having looked at the manual for the fusebox diagram, I can't see anything specifically for the washer (motor) - have I missed something, is it just under the same fuse as the wipers (in which case it's not the fuse)?
Are there any other simple things I should be checking for (wires all seem to be attached to the motor, so that's one simple thing I've checked already at least!)?
Thanks in advance
#2 coopertaz
coopertaz
  • 807 posts
  • Local Club: a-series-magpies
Posted 31 January 2024 - 11:03 AM
only have wiring diagrams up to 96 (so spi) but was same fuse on those as wipers, you will need to check feed to motor with a test lamp or get somebody to press wassher while you hold pump body if there is a supply you may feel a small movement or the pump may get slightly warm but ob. better to check with test lamp if possible. Also remove pipe form pump to make sure not just pipe that is blocked
#3 tmsmini
tmsmini
  • 734 posts
  • Local Club: MOASF
Posted 31 January 2024 - 05:04 PM
From the wiring diagram Fuse B8
