Are All Hif44 Carbs The Same?
16 replies to this topic
#1 ac427
ac427
  • 678 posts
Posted 07 February 2024 - 12:04 AM
I would like to get an HIF44 and refurb it.
There seem to be a few types. I saw a Metro turbo and some Montego ones. Can these be used on a Mini engine or perhaps converted for use on a Mini engine?
#2 timmy850
timmy850
  • 3,346 posts
  • Local Club: MITG
Posted 07 February 2024 - 07:32 AM
There are some that are RH and some are LH. Some have the mechanism for the auto choke. I think if you're in the UK you may as well just get a proper mini one to begin with
#3 nicklouse
  • 18,615 posts
Posted 07 February 2024 - 07:52 AM
There are many different versions. And then there are the different springs/dampers and needles.
ant can be sorted to work on a mini but will need parts/fixings changed to work if not originally off a Mini.
#4 ac427
ac427
  • 678 posts
Posted 07 February 2024 - 08:24 AM
Are there particular part numbers that i should look for?
Edited by ac427, 07 February 2024 - 08:31 AM.
#5 timmy850
timmy850
  • 3,346 posts
  • Local Club: MITG
Posted 07 February 2024 - 09:30 AM
These are the mini ones from what I can tell from my set
Throttle lever JZX 1605
Choke lever JZX 1609
Throttle cable SBB10099
Abutment plate CAM4942
Choke cable clip CZK6491
There’s also nice to have features like a plain throttle blade & the vacuum advance port on the right side of the throttle
There’s a few photos and details I added on the Australian mini forum (and I’m more than happy for any feedback)
https://www.ausmini....hp?f=2&t=102084
#6 KTS
KTS
  • 2,441 posts
Posted 07 February 2024 - 10:00 AM
if you're looking at complete units, which still have the aluminium ID tag attached, the Haynes SU curburettors book lists the following HIF44 specs :
Austin/MG/Vanden Plas Metro 1275 variants : FZX 1280, 1281, 1409, 1412, 1429, 1462
MG Metro 85 on : FZX 1469
For Turbo installs : Austin & MG Metro Turbo   : FZX 1411, 1435
#7 PoolGuy
PoolGuy
  • 848 posts
Posted 07 February 2024 - 10:06 AM
IIRC AC Dodd sells them, might need an exchange though?
#8 ac427
ac427
  • 678 posts
Posted 08 February 2024 - 12:16 AM
Thanks for the great info and excellent link Timmy.
Thanks KTS, Do these numbers appear on the carb's aluminium tag?
Edited by ac427, 08 February 2024 - 12:20 AM.
#9 timmy850
timmy850
  • 3,346 posts
  • Local Club: MITG
Posted 08 February 2024 - 04:56 AM
The tag look like it goes in one of the dashpot screws like this one on eBay. I’m sure most of them have gone missing over the years
https://www.ebay.co....tm/294018281454
#10 gazza82
gazza82
  • 3,015 posts
  • Local Club: TMF+
Posted 08 February 2024 - 10:40 AM
Montego had auto-choke so not going to easy to convert for Mini use.
#11 KTS
KTS
  • 2,441 posts
Posted 08 February 2024 - 12:38 PM
yes; but as mentioned they do tend to be missing
#12 Ethel
  • 25,972 posts
Posted 08 February 2024 - 12:40 PM
The auto-choke is massive and is only half of the system without the ECU. They are are identical to the cable type underneath though.
They had other goodies/unnecessary complexity to try & close the gap with the fuel injected competition, like an electronic overrun fuel cut valve.
#13 ac427
ac427
  • 678 posts
Posted 10 February 2024 - 09:53 AM
Would an FZX 1252 be ok?
I think it was originally fitted to the Jaguar XJ6.
#14 timmy850
timmy850
  • 3,346 posts
  • Local Club: MITG
Posted 10 February 2024 - 10:08 AM
According to this list 1252 is a HIF7 which is 1 7/8” with the earlier style dashpot
https://www.jimhewle...c_1969-1983.pdf
#15 ac427
ac427
  • 678 posts
Posted 11 February 2024 - 08:53 PM
Would an FZX 1435 be ok with the correct needle in non-turbo applications?
Would i be right in thinking the difference is a tougher float that could resist collapsing under boost pressure?
