Hello all,
I have a 1978 mini that I've had for roughly 2 and a half years or so, It has a 1275 non-Cooper S engine that was bored out to 1300 by a previous owner years ago.
I had issues early on with the distributor, it was clearly an original period one and a bit worn out. The one that it came with was vacuum advance so I replaced it with an electric one, also vacuum. I can't recall which place I bought it from online, but it was a 1300 distributor that mimics the look of the stock lucas type. There's also no timing scale on the engine to time with..
I have no knowledge of what was done with the timing chain, or any other alterations internally in the past unfortunately. The modification was done two owners ago, so even the previous owner didn't know but so much.
But the problem I've been having is, I've timed it by ear driving up hill in high gear, stopping somewhere and adjusting, repeating etc. until I couldn't hear the engine pinking anymore. But that's where the problem is, I've had to retard the dizzy so low that if I go any further it starts to bog down. It runs much smoother at idle and in lower gears when I advance it, but then I hear pinking in the higher gears, even on flat ground.
So to protect my engine I've been driving it with the dizzy tuned about as low as it will go to avoid pinking, but I'm also worried about heat issues and such because it's tuned so low. My acceleration is very slow in 3rd and 4th (possibly due to this, but there may be other issues causing it that I'm unaware of). So when getting up to highway speeds, it's extremely sluggish getting her up to speed.
The engine sounds fine for the most part, but I was curious if anyone here knows what the problem might be? Is it proper to use a 1300 dizzy on a bored-out 1275 engine, or is there is there something I should be doing differently?
Thank you all very much for taking a look, any help at all is greatly appreciated..
-Carson
Edited by deadbolt, 10 February 2024 - 11:01 PM.
