Spark Plugs
19 replies to this topic
#1 propjock
propjock
  • 49 posts
Posted 14 February 2024 - 01:59 AM
I just changed the plugs, wires and distributed along with the igniter coil.
When I check the plugs to tune the carb three plugs look rich but the 4th one looks like that cylinder is running very lean. I have set the timing already and checked the compression on all 4 cylinders and they are good.
Any ideas?
#2 68+86auto
68+86auto
  • 1,345 posts
  • Local Club: Queensland Mini Car Club
Posted 14 February 2024 - 02:24 AM
Can you add photos of the plugs?
Edited by 68+86auto, 14 February 2024 - 02:29 AM.
#3 propjock
propjock
  • 49 posts
Posted 14 February 2024 - 03:23 AM
In order 1-4
4 in the problem
#4 propjock
propjock
  • 49 posts
Posted 14 February 2024 - 03:25 AM
Attached File  IMG_0898.jpeg   63.34K   1 downloadsAttached File  IMG_0899.jpeg   54.96K   1 downloads
#5 propjock
propjock
  • 49 posts
Posted 14 February 2024 - 03:27 AM
Attached File  IMG_0900.jpeg   62.46K   2 downloadsAttached File  IMG_0901.jpeg   42.41K   2 downloads
#6 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 14 February 2024 - 04:56 AM
What type of plugs are they?
Is the distributor cap and rotor arm in good condition?
#7 propjock
propjock
  • 49 posts
Posted 14 February 2024 - 05:13 AM
Brand new distributor, coil, wire and plugs
#8 propjock
propjock
  • 49 posts
Posted 14 February 2024 - 05:17 AM
Ngk
Iridium
#9 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 14 February 2024 - 05:24 AM
What spec / number plugs did you buy?
#10 propjock
propjock
  • 49 posts
Posted 14 February 2024 - 05:40 AM
Attached File  IMG_0902.png   86.74K   9 downloadsAttached File  IMG_0904.jpeg   65.24K   7 downloads
#11 propjock
propjock
  • 49 posts
Posted 14 February 2024 - 05:42 AM
Attached File  IMG_0902.png   86.74K   9 downloadsAttached File  IMG_0904.jpeg   65.24K   7 downloadsAttached File  IMG_0904.jpeg   65.24K   7 downloads
#12 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 14 February 2024 - 06:21 AM
Ok so it’s the kit from Jet motors. Is the coil/distributor wires up to a full 12v or are you using an existing ballast wire feed?
https://www.jetmotor...gnition-upgrade
Is this a new issue that’s come up since the new parts were fitted?
Edited by timmy850, 14 February 2024 - 06:23 AM.
#13 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 14 February 2024 - 07:28 AM
Distributor or dissy cap? All timed in correctly?
#14 Steam
Steam
  • 933 posts
  • Local Club: Victorian Mini Club
Posted 14 February 2024 - 07:58 AM
Is it a crappy chinese distributor?
#15 Lplus
Lplus
  • 990 posts
Posted 14 February 2024 - 08:53 AM
What is the fuel system?  Carb? SPi?, MPi?   The plug order seems to be 2, 3, 1, 4 from rich to lean with both the inner plugs being richer than their adjacent outers.  Fuel/air mixing problems in the manifolds?  Minor air leak?
