Scrap Or Spare Parts?
6 replies to this topic
#1 Davidmt
Davidmt
  • 219 posts
Posted 18 March 2024 - 08:55 AM
Over the last couple of months I have replaced the following on my 1980 Clubman 1275GT with new parts.
Clutch hydraulics (Master/slave/arm etc)
Alternator
Starter and solenoid
Brake master
Door winders
Distributor cap, points and leads
Top engine stabiliser
Gear box breather
Heater valve
Heater/choke cables
Sunpro mechanical oil pressure gauge and pipe
Everything was working fine but clearly showing signs of age.  The engine bay is now much cleaner and tidier!
I now have several boxes of dirty old spares which are of no use to me and could do with getting rid.
My question is .... is there any value or parts that could be of use to others, which bits should I just throw away and where's best to sell anything useful?
#2 stuart bowes
stuart bowes
  • 2,246 posts
Posted 18 March 2024 - 09:18 AM
my first step would be to look at the cost of the new items and compare that vs. the effort of refurbing them
heater valve for example is, what, less than £20?  no point messing about with an old one, bin it
cables similar answer
starter and alternator, could get them rebuilt but how much does that cost and how much are new ones
for other parts, can you still get hold of them as new , if not is there already loads used on ebay and how much are they going for, is it worth your time and effort
etc
that's just the way I look at it though others may be desperate for those bits and have a different opinion obvs
Edited by stuart bowes, 18 March 2024 - 09:20 AM.
#3 Lplus
Lplus
  • 911 posts
Posted 18 March 2024 - 09:23 AM
Check out ebay for second hand items like starters and window winders etc.  Asked prices may be more than actual sale prices but would give you an idea what they're worth and if you think it's worth your time to try to sell them.
#4 timmy850
timmy850
  • 3,387 posts
  • Local Club: MITG
Posted 18 March 2024 - 11:31 AM
I’d hold onto everything for a minimum of 12 months, that’s normally how long a poor modern reproduction part will last. Parts like new heater valves and starter solenoids have a habit of lasting just long enough for the seller to void responsibility
It’s handy to keep a known working part aside too if you have the spare. If for example you have a charging issue you can try installing your old one to rule out the new alternator
#5 mab01uk
mab01uk
  • 12,538 posts
Posted 18 March 2024 - 12:17 PM
Original BMC/BL/Rover parts are nearly always better quality than modern reproduction parts if they can be refurbished. Even rubber items are often better cleaned up and re-used if possible rather than fitting short lived new replacements.
#6 68+86auto
68+86auto
  • 1,011 posts
  • Local Club: Queensland Mini Car Club
Posted 18 March 2024 - 12:18 PM
The only thing I'd even consider throwing out would be the hydraulics. everything else I've seen such poor quality in replacements and since they were working I'd rather use them than replacements.
Edited by 68+86auto, 18 March 2024 - 12:18 PM.
#7 Davidmt
Davidmt
  • 219 posts
Posted 18 March 2024 - 07:19 PM
Thanks everyone - I will throw away the dirty hydraulics and cheap to replace stuff and keep a few of the other bits for a while.
Current photo of engine bay to show what's been done so far - not too much more left!
Attached File  20240318_131703.jpg   109.67K   0 downloads
