Hi All
I got a new fuel pump off Magento, the fuel pump doesn't work when on the car. I took it off and it works fine. the spacer is 12mm. and I could feel the cam lobe.
Does any one know the measurement from the Mating face of the pump to the outside face of the lever? I wonder if I bent the lever. I tried to fit it without the spacer. if someone has a spares that they could measure. also, how much play is there in the lever.
Edited by Rusty Mike, 28 March 2024 - 01:43 PM.
