I guess it isn't good news https://photos.app.g...PxoubKvgayWCZh8
OK, that looks to be 0.14 mm or 0.0055" to me !
Has it been re-ground ? If not, this may just be the wear in the mains, they don't wear round, so maybe pop the crank out and check the diameters of the journals in at least 3 places around the diameter. If it's been re-ground (and from memory, it's not), then it has a bend.
While you are set up this way, place your DTI on the Crank Nose and check here too. That's not normally subject to wear and is likely to be more reliable in showing a bend on an un-re-ground crank.
