Thank you very much, I have now ordered the parts at Minispares and will get them next week. I will keep you updated...
By the way, I have another question. I am running an LSD from Swiftune and although it is much more drivable compared to the old salisbury LSD it is still hard in tight bends...
I was thinking of going to a quaife which seems to be the best option.
Is it possible to change the diff without removing the gearbox?? I would keep the ratio. I have a big selection of crownwheels and pinion for both options.
Would it be possible to just change the crownwheel ( as I would need the standard one for the quaife and not the LSD type) with the same gears?
Thank you very much
