Ignition Coil Recommendation
6 replies to this topic
#1 Whizzbang
Whizzbang
  • 64 posts
Posted 16 April 2024 - 04:43 PM
Original coil on my YKG2S2, marked 05-67 has finally given in. This is a 1275 cooper S. What is considered the best replacement for this model?
#2 nicklouse
  • 18,696 posts
Posted 16 April 2024 - 07:46 PM
The correct type.
some reading.
https://www.theminif...tributor-types/
#3 Cooperman
  • 23,326 posts
Posted 16 April 2024 - 10:28 PM
There were some issues with 12 volt coils a few years ago. In particular, the Lucas ones sometimes failed quite early on, even the so-called 'sports' coils.
I recall speaking with Peter Baldwin about it and he said it was all a bit 'hit or miss'.
I had a Lucas one fail and went to my local auto parts supplier and asked what 12 volt coils they had in stock. They sold me a Delphi 12 volt standard coil and it was fine on my 1275 Cooper 'S'. I still have it fitted to that car. My other 1275 Cooper has a Lucas Sports Coil, but bought more recently and it seems to be OK.
#4 68+86auto
68+86auto
  • 1,007 posts
  • Local Club: Queensland Mini Car Club
Posted 16 April 2024 - 10:51 PM
Go find a 4 cylinder points ignition car wreck and take the coil. That's your best chance. It seems nobody can manufacture a good coil now. The coil should be around 3 ohms just in case someone has fitted the wrong coil to a wreck.
Edited by 68+86auto, 16 April 2024 - 10:52 PM.
#5 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 17 April 2024 - 07:48 AM
You’ll need a 3 ohm coil, which is sometimes called a 12v coil
I bought one in 2016 from Tony at AEOW in QLD and it’s been reliable and no problems. He’s an auto electrician who specialises in minis so he’s worth a call
https://www.aeowparts.com/
#6 Cooperman
  • 23,326 posts
Posted 17 April 2024 - 10:10 AM
I've not yet tried one, but I believe the Pertronix coils are excellent quality.
#7 cal844
cal844
  • 9,643 posts
  • Local Club: TFMOC
Posted 17 April 2024 - 11:08 AM
Viper dry coils are excellent, I know AC Dodd recommends and uses them day in day out with hardly any failures
