What do you think, do I leave it to start the engine it on and when I do 100 km I change it for the mineral, or do I change it now?
Thanks in advance!
Edited by PACINO, 20 April 2024 - 05:50 PM.
Posted 20 April 2024 - 05:45 PM
Posted 20 April 2024 - 06:18 PM
Posted 20 April 2024 - 06:58 PM
Change it now, even for a cheap and nasty 20w50,as 10w40 is for more modern engines with tighter tolerances
What happens if the engine fails and he hasn’t followed the engine builders advice?
Posted 20 April 2024 - 07:26 PM
Way back in the 60s, people used 10w40 in winter and 20w50 in summer.
Posted 20 April 2024 - 07:30 PM
Edited by ACDodd, 21 April 2024 - 05:22 PM.
Posted 20 April 2024 - 09:01 PM
If you can get it, a straight mineral 30 grade is good. There used to be Castrol XL, which was a straight 30 grade and that was ideal for initial start-up and the first few hundred miles.
Best not to use a synthetic. I normally use Halfords 20w50 for initial start-up and running in, then switch to Valvoline VR1.
Posted 20 April 2024 - 10:53 PM
Running in a new engine is different to normal running, as above a high zinc running in oil is perfect
It's interesting to note what the Mk1 workshop manual says:
Normal temps above -18C
10W30
10W40
Allowable oils above 12C
20W40
20W50
Cold temps below -18C
5W20
A freshly rebuilt engine should have tolerances on the tighter side compared to a worn out engine, so in some cases 10W40 is an appropriate choice.
Posted 21 April 2024 - 07:43 AM
Do not use synthetic oils, the gearbox synchros will not like it
Posted 21 April 2024 - 10:58 AM
Posted 21 April 2024 - 11:34 AM
Castrol XL was a 20w50 mineral oil which was replaced by GTX. Castrolite was a 10w40 mineral oil for cold climates or winter use.
Used to use XL for all my late 60's rallying. My navigator was the local Castrol Competitions Rep. Came in lovely 5 gallon containers with a tap.
Posted 21 April 2024 - 01:35 PM
This one?Used to use XL for all my late 60's rallying. My navigator was the local Castrol Competitions Rep. Came in lovely 5 gallon containers with a tap.
Edited by PACINO, 21 April 2024 - 01:44 PM.
Posted 21 April 2024 - 07:09 PM
Use running in oil.
Educate yourselves;
https://youtu.be/8wE...3EsGWNH23RNH_Lr
Ac
Posted 21 April 2024 - 11:10 PM
Posted 21 April 2024 - 11:20 PM
are you talking about what 'running in oil' means
it's a type of oil which is for running in an engine. i.e. in the early stages after a rebuild you use it to protect the cams, rings, cylinder bores and so on
(or something more technically accurate than that if you want to get all pedantic but the general idea is right)
Edited by stuart bowes, 21 April 2024 - 11:21 PM.
