I'm assuming from a previous post that Pacino uses Google Translate to post AND read posts. That would explain some of the angst in his posts
Hi PoolGuy! Just a point out. I don't get angry with the answers..
I'll say no more.
Posted 28 April 2024 - 08:11 AM
I'll say no more.
Posted 28 April 2024 - 11:34 AM
Mmmm, having just read through all of this thread lets remember one thing here, we have members from all over the world so language can be a barrier and as some of us know certain platforms like Google etc when using their translation apps can throw up all sorts of random answers that make no sense whatsoever.
Some members may not be able to use the interweb to its full extent for what ever reason so we do not need to be judgmental, be more open minded. Also some answers on here for the less mechanically minded may prove somewhat confusing, so if whoever started the thread and keeps asking multiple questions can be purely down to the language barrier and trying to interpret the answers they have been given.
Hopefully the actual info on here that has been given to PACINO is enough to statisfy their needs and we do not need to denigrate them due to language issues. So please play nicely everyone and also remember everyday is a school day and you always learn something new, no matter how experienced you may or may not be.
Posted 28 April 2024 - 11:57 AM
I fully agree well stated sonikk4
Posted 28 April 2024 - 08:57 PM
I have never had any problems with using a less expensive 20w50 for running in so long as it has good ZDDP levels (min 1200 ppm), then switching to Valvoline VR1 20w50 before really 'using' the engine. Never had any problems
Posted 28 April 2024 - 09:21 PM
I would love to have the space and the funds to do a full restoration on a Mini, so I am lucky to do what I do on the Moop (as my daughter's Mini is called).
Paddy
Posted 28 April 2024 - 09:40 PM
Sensible words. Thanks for everything Sonikk4So please play nicely everyone and also remember everyday is a school day and you always learn something new, no matter how experienced you may or may not be.
Posted 29 April 2024 - 09:48 AM
ulilwhatever oil you decide to use remember that the engine needs to wear slightly to bed all the new components in, that's why running in oil should be used, having said that always use cheap 20/50 for this. when you drain the oil after the initial run in period you will notice the very fine metallic particles in the oil.
Posted 29 April 2024 - 09:50 AM
Cheap 20/50 rather than a running in oil? How about the zddp levels of cheap oils?
Posted 29 April 2024 - 10:02 AM
allways assumed, it may appear incorrectly, that cheap oil had lower adatives must just have been lucky that engine bedded in fine. running in oil for next rebuild then!!! always learning!
Posted 14 May 2024 - 10:36 PM
