Engine Rebuilt. 10W40 Or 20W50 Oil
54 replies to this topic
#16 PACINO
PACINO
  • 801 posts
Posted 22 April 2024 - 12:34 AM
are you talking about what 'running in oil' means
it's a type of oil which is for running in an engine.  i.e. in the early stages after a rebuild you use it to protect the cams, rings, cylinder bores and so on
(or something more technically accurate than that if you want to get all pedantic but the general idea is right)
so.... beautiful explanation. Thank you very much for you help. Could you tell me some name, link or reference of that type of oil... so I can buy it.
Luis
#17 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 22 April 2024 - 01:45 AM
Here’s an example
https://drivenracing...eak-in-oil.html
#18 whistler
whistler
  • 1,870 posts
Posted 22 April 2024 - 08:29 AM
Used to use XL for all my late 60's rallying. My navigator was the local Castrol Competitions Rep. Came in lovely 5 gallon containers with a tap.
This one?
https://i.postimg.cc...descarga-3.webp
That's the container but I had the XL one.
#19 PACINO
PACINO
  • 801 posts
Posted 22 April 2024 - 12:36 PM
Here’s an example
Thank you Timmy! Í could find that oil in my city, but it's very expensive. I'll leave the current oil (10w40) or ... I'll put a basic 20w50 mineral, just to start the engine and to cover the first 100kms.
#20 Cooperman
  • 23,513 posts
Posted 22 April 2024 - 01:10 PM
When I got my first Minis in the early 1960s Castrol was a straight 30 grade, whilst XXL was a 40 grade.
They became multi-grade in around 1965.
The first multi-grade I remember using was a Mobiloil 20w50 in 1964.
I thought that the original Castrol GTX was the first Castrol multi-grade, but after 60 years the memory might be failing a bit.
It's rumoured that BMC Comps Dept were signed up to use Castrol, but in fact used Kendall oil in Castrol tins.
#21 PACINO
PACINO
  • 801 posts
Posted 22 April 2024 - 07:13 PM
Thanks for your contribution Cooperman. About 7 or 8 years ago I heard that many batches of fake Castrol oil cans had been detected. I think nothing is like before. I have this unopened can from Millers. An oil that is considered one of the best, but I don't want to put it in the engine now because it is very viscous. I think it is better to use a less viscous oil now and when the engine has already running, put in the Millers.
#22 PACINO
PACINO
  • 801 posts
Posted 25 April 2024 - 05:46 PM
Hi guys! Anyone know this oil?
"Fuzz Townshend's Classic Oils own-label Hot Hatch oil is a semi-synthetic 10W-40 engine oil meeting the ACEA and API specifications required by many high performance Hot Hatches from the 1980's and 90's. Tested and approved by TV's Fuzz Townshend, star of National Geographic's hit show Car SOS. Blended in the UK to Fuzz's own formulation of top quality mineral and synthetic base stocks, we have produced a high quality engine oil with outstanding properties at a sensible price. Its naturally higher lubricity offers lower internal friction which reduces engine wear and improves fuel economy. It provides excellent stay-in-grade performance for a wide range of later classic engines and boasts a ZDDP content of 1300ppm for reduced wear".
#23 gazza82
gazza82
  • 3,086 posts
  • Local Club: TMF+
Posted 25 April 2024 - 10:09 PM
Think it's just a rebranded Morris Lubricants oil.
#24 PACINO
PACINO
  • 801 posts
Posted 26 April 2024 - 01:51 PM
That doesn't clarify anything.
#25 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 26 April 2024 - 02:59 PM
Nice rude reply there to someone helping.
You’ve asked a question, again.. been told what oil by experts in the Mini scene, ie ac dodd, then asked againnnn about another oil, been told it’s Morris lubricants.
Has google broke or something? or is this generation now where research doesn’t exist. Don’t get it.
Edited by Midas Mk1, 26 April 2024 - 04:25 PM.
#26 PACINO
PACINO
  • 801 posts
Posted 26 April 2024 - 06:52 PM
It's curious that you haven't intervened in such a long post before. Apparently, you were waiting for a supposedly 'rude' response to open your mouth.
Well, so that there is no space for any misunderstanding in the future and with my Google English. When I ask a question here, I would ask you to pretend you don't see it. I repeat; Don't answer anything I ask, nothing. Has it been clear enought to you or has it been too 'rude' for your ears.
Cheers!
#27 PoolGuy
PoolGuy
  • 975 posts
Posted 26 April 2024 - 07:28 PM
It does really, you asked if anyone knew that oil, Gazza told you that it's rebranded ML oil. You didn't ask for clarification on anything.
#28 Midas Mk1
Midas Mk1
  • 5,823 posts
Posted 26 April 2024 - 07:41 PM
Cheers!
We have manners on this forum, you? - learn them
How to make an impression.
Edited by Midas Mk1, 26 April 2024 - 07:42 PM.
#29 stuart bowes
stuart bowes
  • 2,530 posts
Posted 26 April 2024 - 08:05 PM
when they say 'rebranded' they're saying it's another manufacturers oil with a different label stuck on it
i,e if you want details on it, look at the morris brand and assume it will be the same
sometimes a language barrier can make things come across the wrong way, if you want snarky comments and pointless arguments maybe facebook is the place to be
Edited by stuart bowes, 26 April 2024 - 08:05 PM.
#30 PACINO
PACINO
  • 801 posts
Posted 26 April 2024 - 11:48 PM
I asked 'does anyone know this oil?' When I ask this I'm referring to whether anyone has used it, what sensations they have had in terms of lubrication, smoothness in the gearbox, noise of the rocker train, hot pressure levels... consumption. Any information was welcome.
