Indicator Stalk Mk2
Posted 21 April 2024 - 11:45 AM
Is it a whole new stalk that’s needed or anyone know if just the clip can be replaced?
Posted 23 April 2024 - 10:05 AM
I guess it's just reached the end of its fatigue cycles, pretty impressive if it's original. I suppose you could try to give it some external assistance (laggy band?), but it could be time to replace it - bet it doesn't last as long, unless you can find a new old stock gem.
Posted 23 April 2024 - 11:55 AM
Posted 13 May 2024 - 09:15 PM
So update. I bought a new old stock Lucas stalk and harness. Happy days. Question I have now though is about the connector block. I haven’t had a good look but where about is it on the mk2?
the wire doesn’t look very long so kind if wondering if I need to cut and strip then solder them in.
Posted 13 May 2024 - 10:03 PM
All the wiring, including the connector, should be hidden inside your plastic steering column cowl. Should be no need to lengthen any wiring.
Posted 14 May 2024 - 03:56 AM
Posted 14 May 2024 - 11:24 AM
It looks like some punters are flogging them without the connector housings. Possibly not actually NOS, or for a different model. If it has the same metal connectors you should be able to free the housing from the old switch's wiring with a small instrument screwdriver inserted to hold down the retaining tang.
Posted 14 May 2024 - 02:00 PM
Great news. Stalk changed. 10 minute job. All working like new. Made up
