Oil Pressure And Oil Capillary Gauges From The Same Bulb
8 replies to this topic
#1 ac427
ac427
  • 698 posts
Posted 28 April 2024 - 03:43 PM
I'd like to fit both an oil pressure and oil temperature mechanical gauges to my Mini.
I was wondering if they could be fed from the same capillary bulb using a T-piece at the back of the gauge binnacle?
#2 Ethel
  • 26,144 posts
Posted 28 April 2024 - 05:14 PM
I'd say no. They both rely on expansion in a fixed volume, so one would detract from what the other records at the gauge end and add to it at the sensor end.
#3 nicklouse
  • 18,742 posts
Posted 28 April 2024 - 06:15 PM
Certainly not. You would render both useless.
#4 ac427
ac427
  • 698 posts
Posted 28 April 2024 - 08:36 PM
Thank you both. When I actually thought about it. It was a bit silly.
Hopefully an electric oil temperature sensor won't be too big. I've seen some and they look almost the same size as the 52mm gauge.
#5 68+86auto
68+86auto
  • 1,035 posts
  • Local Club: Queensland Mini Car Club
Posted 29 April 2024 - 01:18 AM
The large sensors are for oil pressure. Temperature sensors should still be small.
#6 gazza82
gazza82
  • 3,025 posts
  • Local Club: TMF+
Posted 29 April 2024 - 08:21 AM
Mechanical/capilliary sensors aren't small!! There not 52mm either but are much larger than electric senders.
#7 nicklouse
  • 18,742 posts
Posted 29 April 2024 - 08:53 AM
I should add. Mechanical oil pressure gauges are connected just by a hose. The temp ones have a bulb.
temp ones need to be in moving oil pressure don’t. I would not be looking to fit in the same place.
#8 Shooter63
Shooter63
  • 1,103 posts
Posted 29 April 2024 - 07:41 PM
To get the true oil temperature you need a sensor fitted in the sump, good old Minispares has an adapter, bad news is that you loose the magnetic sump plug, although you could weld a fitting to the gearbox case and have both.
Shooter
#9 nicklouse
  • 18,742 posts
Posted 29 April 2024 - 08:06 PM
I would not do the sump one. Retrosport do a filter housing that can take a few different fittings for temp senders.
