Hi All,
Hopefully you can either put my mind at rest or point me in the right direction. My mini has a slight whirring noise at idle, that will quieten if the clutch is depressed (but not go away) and also isn't audible if the rev's increase.
I have uploaded a video to my website, which hopefully you can access.
https://tinoest.co.uk/img/IMG_8086.mov
https://tinoest.co.uk/img/IMG_8131.mov
I thought it might be the idler gear bearing, but it's more prominent on the water pump side than the clutch.
Is this just a standard normal sound? I can't hear it whilst in gear and over the normal engine and road noise, but that's not to say it's not there.
Thanks for any advice.
