I bolted the radiator to the cowl, and attached the bottom hose then put the whole thing in. I figured I would try that first instead of separately as it would be easiest if it worked, and there was space.
The bottom host to water pump was a nightmare, but got it in the end.
The problem came when I went to put the top bracket on and realized the rad felt a little loose at the bottom. Cue checking the diagrams and realizing I had missed two rubber grommets and a piece in the bottom bracket to keep it snug.
Somehow, don't ask me how... I got those in without removing everything, but now when the radiator is in place the fan scrapes the bottom of the cowl.
I can't figure out what I can do to fix this, as there is no play in anything to lower the cowl at all. The cowl, fan and radiator are all replacements, but it is the standard one piece cowl, fan and Mini Spares two core radiator.
I changed the water pump and pulley too, is there any chance the replacements set the fan too low?
Thanks for any advice, I thought I was so close to getting this in and finished!
EDIT: I should have said, it's a 1990 Mini City
Edited by Shylos, 01 May 2024 - 04:08 AM.
