Rv1/1003/00 Tach
2 replies to this topic
#1 Whizzbang
Whizzbang
  • 64 posts
Posted 07 May 2024 - 10:06 AM
Having wired the RV1/1003/00 tach according to wiring diagram for -ve earth, the needle
immediately shoots to the right hand end of the scale. This tach was originally fitted to my
car when it was +ve earth. Is that the problem?
#2 timmy850
timmy850
  • 3,425 posts
  • Local Club: MITG
Posted 08 May 2024 - 10:25 AM
The RVI type tacho normally doesn't work with electronic points
All you need to know about RVI and RVC Smiths tachos is here:
https://www.triumphc...pdfs/Smiths.pdf
#3 DeadSquare
DeadSquare
  • 3,218 posts
Posted 08 May 2024 - 11:28 AM
I had the same happen with a 0-8,000, swapping tach from a +ve to -ve, as per an Autosport article, and assumed the tach was dud; I tried a 0-10,000 from the race car, which was about ten years older, and it worked.
Weird.
