Depining A Multipin Connector.
Best Answer Ethel , 15 May 2024 - 10:15 AM
I have some Superseal connectors. They have a similar plastic insert with  tangs on the underside that lock the pins, so I expect you'd need  to remove the yellow bit to release them all. you still have to wonder the smaller holes are for & why not all pins have 'em  :huh:
Go to the full post
9 replies to this topic
#1 MikeRotherham
MikeRotherham
  • 980 posts
Posted 14 May 2024 - 03:31 PM
Has any one ever removed a pin or pins from a multipin connector?
The connector I'm referring to is situated adjacent to the glove box behind the dash on my 1994 1275 Mayfair.
This loom that this connector goes back to the boot area.
I appear to have a broken wire (blue/yellow) that stops the rear fog light working.
The connector (male) has a yellow insert that I think should pull out to be able to access the clip holding the pin in to be able to pull it back.
#2 KTS
KTS
  • 2,454 posts
Posted 14 May 2024 - 03:52 PM
typically each pin will have it's own locking barb within the connector, and the connector may have a 'gate' that holds all the connectors in place
if you can upload a photo it may help identify what type it is and how it goes together
#3 Chris1275gt
Chris1275gt
  • 959 posts
Posted 14 May 2024 - 04:31 PM
If you’re wanting to remove a pin from a multi pin plug I bought a set of these eBay item number 114890973735. Theycover a range of multi plugs.
Edited by Chris1275gt, 14 May 2024 - 04:32 PM.
#4 Spider
  • 15,038 posts
Posted 14 May 2024 - 06:20 PM
I'm not sure of the type of connector this is, but if it has round pins, you'd use a tubular tool, similar to this in Chris's post above. If it has flat pins, you insert a small flat blade jeweler's type screwdriver down one side of the blade to release the retaining barb.
#5 Avtovaz
Avtovaz
  • 1,263 posts
Posted 14 May 2024 - 07:50 PM
i dont know the plug , but id bet its an econoseal connector. That tool set linked above i have one too,  it works, durite do 6 pointed ones, they work well too.
#6 MikeRotherham
MikeRotherham
  • 980 posts
Posted 14 May 2024 - 08:45 PM
Sorry the images are so massive my antique copy of Photoshop Elements 6 no longer works on Windows 11.
I'm assuming the yellow insert is removable to remove the blue and yellow pin
Edited by MikeRotherham, 14 May 2024 - 08:54 PM.
#7 Icey
Icey
  • 1,551 posts
Posted 14 May 2024 - 09:48 PM
I have a pick from a lock picking kit which is perfect for depinning most plugs.
#8 Ethel
  • 26,022 posts
Posted 14 May 2024 - 10:28 PM
It's an AMP Econoseal connector
#9 Ethel
  • 26,022 posts
Posted 15 May 2024 - 10:15 AM   Best Answer
#10 MikeRotherham
MikeRotherham
  • 980 posts
Posted 15 May 2024 - 03:36 PM
Sorted Now.
Thanks for all the info.
