Masking Question (And No, Its Not Covid Related)
5 replies to this topic
#1 croc7
croc7
  • 894 posts
Posted 15 May 2024 - 05:17 AM
I will be painting the spokes of a set of Revo wheels.  Rather than masking tape, I thought I might apply a thin coat of petroleum jelly to the polished rims to prevent overspray.  Will this work?
Edit:  Didn't consider that getting a nice sharp edge would be difficult - masking tape it is.
Edited by croc7, 16 May 2024 - 12:50 AM.
#2 slidehammer
slidehammer
  • 1,205 posts
  • Local Club: LSMOC
Posted 15 May 2024 - 12:27 PM
That is not a good idea as you risk getting contaminates on the area you want to apply paint to and it would cause paint issues. Proper painter masking tape is the way forward. Also getting a hard defined edge would be a problem,
#3 Midas Mk1
Midas Mk1
  • 5,851 posts
  • Local Club: S.U.N.M.C
Posted 15 May 2024 - 12:41 PM
3m blue tape, sorted.
#4 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 16 May 2024 - 01:17 AM
I used this fine line tape when i was prepping my Cluuby for seam sealing
https://www.vital-pa...fRoCZsYQAvD_BwE
#5 Homersimpson
Homersimpson
  • 851 posts
Posted 19 May 2024 - 09:11 AM
I've used electrical insulation tape in the past as it enables you to follow curves much more nicely than masking tape.
#6 stuart bowes
stuart bowes
  • 2,619 posts
Posted 19 May 2024 - 09:27 AM
In some cases the old paper gasket trick works well, I.e cover a piece with tape overlapping the edges then gently tap with the small hammer around the edges to get a perfect fitting edge
Not really for wheels as such but have used a lot for parts like track rod arms or brake calipers where there's a bit that needs to stay bare
