Layshaft
7 replies to this topic
#1 Whizzbang
Whizzbang
  • 64 posts
Posted 06 June 2024 - 12:37 PM
Is it possible to remove the layshaft from a 22G1128 4 speed synchro box without removing the mainsheet etc.?
#2 Whizzbang
Whizzbang
  • 64 posts
MAINSHAFT !!!
#3 GraemeC
GraemeC
  • 7,440 posts
Posted 06 June 2024 - 02:58 PM
Yes.
In fact you'd always remove it first even if you wanted to remove the mainshaft (1st and 3rd motion shafts)
#4 Whizzbang
Whizzbang
  • 64 posts
Posted 06 June 2024 - 03:13 PM
that's good news. `But despite having a Haynes Manual I can't see how to remove it. I'm missing something.
There is a slot across the outer end of the shaft. Does that unscrew?
#5 imack
imack
  • 2,207 posts
Posted 06 June 2024 - 03:33 PM
You've got to take thev4 bolts out of the mainshaft double row bearing retainer. Remove the retainer and shims along with the locking plate which secures the layshaft and reverse idler shaft. Layshaft will then slide out. Need to remove the oil pickup pipe to lift the laygear out to access the bearings.
Edited by imack, 06 June 2024 - 05:15 PM.
#6 GraemeC
GraemeC
  • 7,440 posts
Posted 06 June 2024 - 03:40 PM
No, it doesn't unscrew
You need to remove the drive pinion that meshes with the diff crown wheel. (which will be tight - you will need to lock the 'box into 1st and 4th gears and also find a way of holding it down whilst you heave on the nut)
Then the bearing retainer behind that, which will release a small triangular plate that locks into the layshaft and the reverse idler shaft
The the layshaft should withdraw towards the input gear end of the 'box
(I've never attempted it, as I'm usually stripping the 'box down anyway, but you might be able to remove the bearing retainer without taking off the pinion).
There's loads of videos on Youtube if you can't follow the Haynes instructions.
Edited by GraemeC, 06 June 2024 - 03:46 PM.
#7 Whizzbang
Whizzbang
  • 64 posts
Posted 07 June 2024 - 09:34 AM
Problem found. In the gearbox I've found 3 small pieces of a flat magnet which could have the shape of a keyway. These pieces were causing a jam.
Should there be a magnetic keyway somewhere or has someone dropped one in it?
#8 GraemeC
GraemeC
  • 7,440 posts
Posted 07 June 2024 - 10:18 AM
None of the keyways are intentionally magnetic - the only magnet is in the sump plug (or a second plug where the pick-up pipes bolts to the back of the casing if its been fitted with an 'upgrade' there).
