Crankshaft Pulley On Mpi - Should It Rotate By Hand?
Best Answer Midas Mk1 , 08 June 2024 - 08:47 PM
Sorry photo didn’t attach - now attached. I can’t rotate this pulley by hand - the bigger pulley of the two at the backNo photo.
no it should be rotated by the crank. Sounds like the key has failed.
That’s the crank pulley, to rotate it your fighting the compression of all 4 cylinders. It’ll only rotate with large leverage. Go to the full post
Posted 08 June 2024 - 08:07 PM
Posted 08 June 2024 - 08:18 PM
No photo.
Posted 08 June 2024 - 08:19 PM
You are correct.
The rotating crank shaft, through the pulley keyed and bolted on to it, drives, by way of a belt, the water pump and the electric generator.
Posted 08 June 2024 - 08:37 PM
Edited by s2ulk, 08 June 2024 - 08:38 PM.
Posted 08 June 2024 - 08:39 PM
Posted 08 June 2024 - 08:47 PM Best Answer
Posted 08 June 2024 - 08:50 PM
Posted 10 June 2024 - 10:11 AM
Ensure to not overtighten the aux drive belt as this can overload the water pump and tension pulley bearings causing early failure. From the manual (belt position 'X' is just below the alternator in line with the alternator lower mounting bolt):
Perhaps this should say: "...between the crankshaft pulley and tensioner pulley."
Also be careful not to overtighten the tensioner pulley retaining nut (25Nm) as from direct experience this stud is easily sheared.
PS it is also worth putting anti-seize grease on the long tension adjusting bolt while you are working in the area - this is very exposed and prone to corrosion.
Edited by Deeppockets, 10 June 2024 - 10:15 AM.
