Strip Down Peculiarities
9 replies to this topic
#1 Gaz66
Gaz66
  • 960 posts
Posted 10 June 2024 - 03:43 PM
When I stripped my shell I noticed that the rot was far worse on the drivers side, floorpan, bulkhead, flitch, hinge panel etc etc whereas the passenger side was near original condition.
Having just acquired a front subframe I decided to strip it ready for blasting and noticed the drivers side pins, bushes, bolts etc were in very good condition with even the gold protective coating still there mostly on the bottom arm pin.
Moving to the passenger side .. everything solid, bushes wrecked and bolts massively corroded.
What the hell causes such dramatic differences of condition in different sides of the car?
I could understand if it was all the same side that suffered but it doesn't seem to be that way.
Edited by Gaz66, 10 June 2024 - 03:44 PM.
#2 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 10 June 2024 - 03:54 PM
Is it a late one?
I've noticed that the driver's side usually is the most corroded.
No idea why!
#3 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 10 June 2024 - 04:22 PM
You would have thought it would be the passenger side as that is the side that spends more time driving through puddles in the gutters or the road.
#4 Gaz66
Gaz66
  • 960 posts
The shells an 87 but not sure of the subframe.
#5 Homersimpson
Homersimpson
  • 834 posts
Posted 10 June 2024 - 06:21 PM
All cars i've restored have been worse on the drivers side than the passengers side, i've always assumed that it was because the passengers side gets the salt washed off more by the water in the gutter whereas the drivers side doesn't and so its subjected to a stronger salt concentration for longer.
Might be complete nonsense but thats always been my theory!
#6 Chris1275gt
Chris1275gt
  • 965 posts
Posted 10 June 2024 - 06:48 PM
I’ve always thought it was because the warm air blowing out through the wheel arch on the passenger side keeping it drier, or is my fan on the wrong way round?
Edited by Chris1275gt, 10 June 2024 - 06:49 PM.
#7 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 10 June 2024 - 07:00 PM
It's the same way on MPi's, with front mounted radiators, so that pops that theory.
#8 Homersimpson
Homersimpson
  • 834 posts
Posted 10 June 2024 - 07:53 PM
I've found the same on the Jags and Austin Healeys i've done as well as a VW camper, always the driver side thats worse.
#9 mm man
mm man
  • 405 posts
Posted 10 June 2024 - 08:17 PM
A car salesman will tell you it’s roundabouts  :whistling:
#10 coopertaz
coopertaz
  • 806 posts
  • Local Club: a-series-magpies
Posted 11 June 2024 - 11:22 AM
drivers wet feet?"! depends how often passenger was in. i always found drivers floorpan worse but passenger side flitch and scuttle underside worse put that down to puddles on nearside of road?!
