Clutch Oil Seal, Tool Dimensions
5 replies to this topic
#1 aguiloco
aguiloco
  • 53 posts
Posted 11 June 2024 - 02:37 PM
Hi, I'm cheap and I'm going to make the tool to press a new oil seal.
I imagine some of you have this tool, would you kindly tell me the dimensions A, B, C, and D?
Much appreciated.
#2 slidehammer
slidehammer
  • 1,197 posts
  • Local Club: LSMOC
Posted 12 June 2024 - 11:49 AM
I have never used the tool to fit new oil seals (I am even cheaper than you!) and usually wrap the spline in masking tape and tap the new seal on gently with a large soft drift making sure it goes in square (take it slowly) and I have never had any seal issues.
#3 KTS
KTS
  • 2,483 posts
Posted 12 June 2024 - 01:10 PM
mine measures as follows:
A = 58.9mm
B = 69.5mm
C = 75mm
D = 1.7mm
also worth noting that the outer edge of the shoulder (B dimension) has a chamfered edge - presumably to aid centering into the clutch seal housing bore
#4 aguiloco
aguiloco
  • 53 posts
Posted 12 June 2024 - 04:55 PM
Thank you KTS! I'm going to 3D print it. I know the job can be done without the tool, but it will be safer this way.
#5 colinf1
colinf1
  • 1,035 posts
Posted 12 June 2024 - 07:50 PM
There already is a file available for this to be printed....here's one I printed in action
https://www.theminif...leated-designs/
#6 aguiloco
aguiloco
  • 53 posts
Posted 12 June 2024 - 08:39 PM
WoW, you have a library of 3D files here? Impressive!
It is an easy design to make but I'll check out the existing model.
Thanks!
