Manifold Advice
6 replies to this topic
#1 stevie77
stevie77
  • 33 posts
Posted 16 June 2024 - 12:31 PM
Hi, I have a 1993 Mini Rio with a 1275 engine with an carburettor.
Apart from an RC40 exhaust from the cat back, the car is standard.
The problem I have is there is a loud rasping noise coming from around the manifold area, it sounds like the exhaust is blowing.
I have already took the manifold off, and couldn’t see any cracks or holes on it, the gasket was in bad condition, so I replaced it with it with a new one, and put it back on.
I also replaced the clamp from the manifold to the down pipe, but this has made no difference, still the noise is there.
I have checked all around the manifold area, but can’t find anywhere obvious it is leaking from.
I have now taken the down pipe off, but again can’t see any cracks or holes in that either.
Any advice on what I can check next?
Many thanks.
#2 Spider
  • 15,684 posts
Posted 16 June 2024 - 07:36 PM
If it is an exhaust leak, there'll be evidence of where that's occurring from the black soot at the leak.
If can also lower a piece of paper around the back of the engine and exhaust, in some long needle nose pliers or even a coat hanger wire. As you get around the leak, you'll see the paper starting to flap about.
#3 stevie77
stevie77
  • 33 posts
Posted 16 June 2024 - 08:07 PM
Thanks Spider. I will have another look tomorrow and see if I have missed some black soot anywhere.
I will give the paper on some long nosed pliers a try like you suggested as well.
#4 viz139
viz139
  • 721 posts
  • Local Club: Irish Mini Owners Club
Posted 17 June 2024 - 09:07 AM
Get a length (60cm) of narrow pipe (15-20mm)  .With one end to your ear  move the other end around the back of the engine until you find the loudest point.
#5 Tones61
Tones61
  • 440 posts
Posted 17 June 2024 - 12:12 PM
rubber fuel hose is decent to hear :-)
#6 stevie77
stevie77
  • 33 posts
Posted 20 June 2024 - 05:16 PM
Thanks I will give this a try as well 👍
#7 stevie77
stevie77
  • 33 posts
Posted 20 June 2024 - 05:18 PM
Thanks will try that 👍
