Hi,
I recently rebuild the entire front subframe of my 1994 1.3 Mini: New brake hoses, pipes, rebuild calipers, new discs and pads, rebuild brake booster, new suspension bushings, etc.. everything was fine the first 200Km.
But then the brakes have started acting up, i would have a great initial pedal feel then suddenly the pedal drops down a little and you can feel it bite down again.
It doesnt drop all the way to the floor and it keeps braking, but it feels weird that it has this "soft" spot you can push trough.
This then doesn't happen everytime you use the brakes so its always a suprise when it does.
Since this happend i bled the system multiple times, replaced master cylinder (green tag), rear wheel cylinders.
Something i have also noticed is that engine runs a little rougher when you come to a complete stop when the problem occurs, if you release the pedal it runs fine .
When replacing the master cylinder i also found out that i switched the brake lines from the master cylinder to fam 7821 around.
Afther switching these the problem became rarer but still occurs, could i have damaged the brake valve by plumbing it incorrectly maybe causing it to release pressure internally causing this issue?
Or does anybody ever had this problem, are these symptoms of a possible bad brake valve?
Thank you.
Edited by Coene614, 17 June 2024 - 08:21 AM.
