Coolant Flush Advice Mpi
2 replies to this topic
#1 TheRedSl#t
TheRedSl#t
  • 10 posts
Posted 19 June 2024 - 02:20 PM
Ive found rust and dirt in my water tank 🙄
So here's how I'm going to attempt it,
While engines cold, remove bottom hose from rad drain collant,
reconnect bottom hose,
fill with tap water and Radiator detergent
Start engine for ten minutes, heater on hot blower, expansion tank pressure cap off
Let engine cool down to cold and empty out tap water/detergent via bottom hose
then run an garden hose through expansion tank to clear detergent till water runs clear
Reconnect bottom hose and add 50/50 mix of rover OAT pink coolant and deionized water? ... I have no distilled water
Run engine with preaure cap off, burp air bubbles out till gone with the hot air heater on?
Advice needed as this is my first attempt doing an coolant flush
#2 Steve220
Steve220
  • 5,115 posts
  • Local Club: BMC
Posted 20 June 2024 - 10:46 AM
You're kinda there. Drain it, fill it back up with water and add a dishwasher tablet in the expansion tank. Run the engine for about 50 miles and then drain.
You need to reverse flush the engine, so remove the hose going from the stat housing to the heater matrix and put a garden hose in to push it back towards the housing. Remove the radiator top hose, put the expansion tank cap on and turn the tap on. Run until it is all clear. Replace with OAT and water 50:50 mix, do not fill to the max line in the expansion tank.
#3 TheRedSl#t
TheRedSl#t
  • 10 posts
Posted 21 June 2024 - 11:17 AM
Thank you steve 😎👍
