Hesitation When Cruising Most Noticeable At Low Speed
5 replies to this topic
#1 andrewdjackson
andrewdjackson
  • 25 posts
  • Local Club: Basingstoke Mini Owners Club
Posted 24 June 2024 - 09:48 PM
I have a 1965 850 and have an issue with it hesitating only when cruising, most notably around 20-30mph. The hesitation seems to be regular.
The car ticks over lovely no hesitation. It accelerates well and appears not to be hesitating at higher speeds (40+). I have a good spark on all cylinders, have changed the plugs, ht leads, dizzy cap, rotor arm, points and condenser. Dwell is rock solid around 61 at idle, rising to 63/64 when revved. Timing reads around 7/8 and is steady. Dizzy shaft doesn’t have much lateral movement and easily rotates and returns when turned by hand.
So I’m a bit stumped what to check next. TIA
Edited by andrewdjackson, 24 June 2024 - 09:49 PM.
#2 Chris1275gt
Chris1275gt
  • 965 posts
Posted 24 June 2024 - 10:49 PM
I’d check the piston in the carburettor is clean and not sticking just to discount it and the oil in the dash pot.
#3 Spider
  • 15,091 posts
Posted 25 June 2024 - 12:59 AM
It sounds like it's running lean at cruise.
Worn throttle shaft ?
#4 Lplus
Lplus
  • 911 posts
Posted 25 June 2024 - 07:06 AM
When you say it seems to be regular, do you mean it feels like just 1 cylinder is misfiring regularly?
#5 andrewdjackson
andrewdjackson
  • 25 posts
Posted 25 June 2024 - 08:34 AM
Thanks Chris, I need to check the carb but I did check the dash pot.
#6 andrewdjackson
andrewdjackson
  • 25 posts
Posted 25 June 2024 - 08:41 AM
Perhaps, but it's quite subtle and when I stop and check if I have a spark on all cylinders and check the burn on the plugs it all looks good. Once I accelerate to a higher speed it seems to go away, of course it could still be there but there's enough momentum that it's not noticeable.
