Rattle After Flywheel And Clutch Replacement
4 replies to this topic
#1 aguiloco
aguiloco
  • 53 posts
Posted 26 June 2024 - 07:25 PM
Hello, maybe some remember that recently I bought a Mini, and the flywheel detached from the crankshaft in the first drive after 30 minutes.
Here is the original post about it:
https://www.theminif...ut-the-flyweel/
I mounted a new MED ST1 flywheel/clutch set following instructions given by Spider, rww, and other gurus around here.
I took it for a short ride and all seemed fine, good clutch control, no slippage, and downshifts were good without any grinding.
When I came back after 10 minutes I noticed a strange rattle that goes away when the clutch is pressed, so something is not right, unfortunately.
When the engine is cold is not noticeable, but after a few minutes it starts to be, and it doesn't sound good...
This is a short video I just made:
https://youtu.be/VVc...Tu-GR24lVwz5mAW
Any idea of what could be happening?
Thank you very much
#2 Lplus
Lplus
  • 911 posts
Posted 26 June 2024 - 07:43 PM
Thank you very much
Sounds to me like idler gear rattle.  Try speeding up the tickover.
#3 aguiloco
aguiloco
  • 53 posts
Posted 30 June 2024 - 03:29 PM
Seems like increasing idle speed did the trick, now I can't barely hear any change in sound at idle.
Here a short video of the engine running, do you think it sounds decent? I'll enjoy the car a bit before tearing the engine apart.
https://youtu.be/d1y...g95kcpAvHb624Ts
Thanks!
#4 Lplus
Lplus
  • 911 posts
Posted 01 July 2024 - 07:27 AM
Thanks!
That sounds a lot better.  I don't know what cam you have in it but the hotter the cam the rougher the idle will be and the more likely you are to get idler gear rattle until the idle speed is increased.  A lightweight flywheel might also add to the problem.
edit - nice looking mini by the way. :thumbsup:
Edited by Lplus, 01 July 2024 - 07:29 AM.
#5 aguiloco
aguiloco
  • 53 posts
Posted 01 July 2024 - 09:17 PM
Thanks! It has a Kent 266 and a lightweight flywheel, I'm sure there is some wear at the idle gear bearings and primary, but seems fine for a few miles.
How do I mark this post as answered? I have seen some post with that annotation, seems appropriate.
