Oil Leak Testing
4 replies to this topic
#1 Whizzbang
Whizzbang
  • 64 posts
Posted 29 June 2024 - 12:09 PM
I've just had the engine out of my mk1 cooper S and want to try to pretest for oil leaks before replacing. I'm aware that it won't be definitive but might show any major leaks. Any great ideas, people?
#2 Spider
  • 15,235 posts
Posted 30 June 2024 - 03:19 AM
Run it.
#3 Whizzbang
Whizzbang
  • 64 posts
Posted 30 June 2024 - 08:29 AM
I'll fire it up while it's hanging on the engine crane
#4 timmy850
timmy850
  • 3,412 posts
  • Local Club: MITG
Posted 30 June 2024 - 09:21 AM
Mini engines are nice and flat on the bottom & easy enough to get started on the floor. I probably wouldn’t try it on an engine crane or stand
#5 DeadSquare
DeadSquare
  • 3,206 posts
Posted 30 June 2024 - 02:28 PM
A Mk 1 S will probably have a cam cover plate with a vent pipe in it and another vent in the rocker cover.
Make sure that the hoses from these are in good condition and either individually or through a T connector, are fed into the inlet manifold.
Under normal motoring conditions, except when accelerating hard, there is a partial vacuum in the inlet manifold, and through the aforementioned hoses this partial vacuum within the engine is constantly trying to draw surrounding air into the engine through even the slightest orifices, out of which, without the pressure differential, oil might otherwise be tempted to try and leak.
