Crank End Float Issue
Posted 05 July 2024 - 06:59 PM
Posted 05 July 2024 - 07:48 PM
I'd say it's likely from oil on the crank making one set of thrusts stick to the crank. As you move the crank, the thrusts are moving with it, leaving the clearance on the backside of the thrusts.
Posted 05 July 2024 - 07:57 PM
Do you reckon it be ok then?
Posted 06 July 2024 - 12:50 AM
I'd suggest check what the issue is here. I've only suggested what I think it could be.
Posted 06 July 2024 - 03:15 PM
Shooter
Posted 06 July 2024 - 08:23 PM
How are you pushing the crank from side to side, levers ?
If pushing it by hand it will be very hit and miss due to the oil on the bearing taking up the slack as Spider has suggested.
Posted 06 July 2024 - 09:18 PM
Hi Mini 100 S
The above excellent replies are aimed at your technique in getting repeatable results, Just for extra caution ( : DO NOT move on until you are absolutely sure of your measure - and as to what you are aiming for.- probably different thoughts on this - but mine are 4 thousand is fine for a normal road car - maybe aim for 5 or 6 thous if you regularly rev out above 6- 6500rpm.
