Replacing Fuel Pump On 1974 Mini 1000
10 replies to this topic
#1 Nemo_86
Nemo_86
    Starting My Mini Up
  • 2 posts
Posted 08 July 2024 - 02:08 PM
I have been having issues finding a replacement fuel pump for my 1974 Morris mini 1000, does anyone know what part i need an where to get it also any tips on the best way to replace it would be handy.
#2 Ethel
  • 26,022 posts
Posted 08 July 2024 - 02:16 PM
https://www.minispar.../AZX1818MS.aspx should do you.
..unless it's been swapped for an electric pump.
#3 weef
weef
  • 503 posts
Posted 08 July 2024 - 02:35 PM
I bought a replacement mechanical pump from said retailer and found it a bit lacking.
Firstly it developed too much pressure and overrode the float valve, leaking fuel everywhere and secondly the outlet port pointed directly at the exhaust downpipe making the fuel pipe pass dangerously close to it , in my oppinion, not like my origional where both the inlet and the outlet ports pointed away from the exhaust.
I abandoned the mechanical unit, fitted a blanking plate to the engine port and used an electric unit, solving the problems mentioned above.
#4 Nemo_86
Nemo_86
    Starting My Mini Up
  • 2 posts
Posted 08 July 2024 - 02:38 PM
thanks for the info as I am new to working on cars do you know of any good tutorials for fitting the fuel pumps
#5 Designer
Designer
  • 610 posts
  • Local Club: LSMOC
Posted 08 July 2024 - 03:15 PM
If you want a genuine replacement then www.bullmotifminispares.co.uk has got them. A bit more expensive but should not give you any problems. Sorry cannot get link to work.
May I suggest that you obtain a copy of the Haynes Manual for classic Minis 69-95. Get a hard copy, not this new fangle electronic version they seem to be doing nowadays. There is one on fleabay for £10.95
or on fleabay
Mini Workshop Manual 1959-1976: AKD 4935: Saloon, Countryman and Traveller, Clubman, Estate and 1275 GT, Van, Pick-Up and Moke, Cooper and Cooper 'S' (Official Workshop Manuals) Paperback – Illustrated, 1 Jan. 1976
by British Leyland Ltd (Contributor) for £35.00
Edited by Designer, 08 July 2024 - 03:16 PM.
#6 mab01uk
mab01uk
  • 12,484 posts
Posted 08 July 2024 - 03:51 PM
Mechanical Fuel Pump (Genuine SU) 1969-1990
AZX1818
"This is the later improved genuine SU mechanical fuel pump for all models from 1969 to 1990. Fits 848cc, 998cc, 1098cc and 1275GT models. It replaces the earlier AUF crimped types which were prone to leaking."
https://www.bullmoti...azx1818/AZX1818
Edited by mab01uk, 08 July 2024 - 03:51 PM.
#7 mab01uk
mab01uk
  • 12,484 posts
Posted 08 July 2024 - 03:56 PM
Fuel Pump Access:-
https://www.theminif...el-pump-access/
This video below may also help.
Edited by mab01uk, 08 July 2024 - 03:56 PM.
#8 Designer
Designer
  • 610 posts
  • Local Club: LSMOC
Posted 09 July 2024 - 05:20 AM
Thank you mab01uk for posting the link.
Paddy
#9 mbolt998
mbolt998
  • 392 posts
Posted 09 July 2024 - 07:41 AM
Moss also do the "genuine" kind (probably this one, but double-check). I have one on my car and it works fine.
https://www.moss-eur...hanical-azx1818
#10 Ethel
  • 26,022 posts
Posted 09 July 2024 - 11:28 AM
Sure there used to be one where you could rotate the hose couplings, like the leccy pump.
If you might be contemplating an exhaust manifold swap, then the solid state leccy pump could be a good option. Best mounted below the fuel tank so it's gravity fed.
https://www.minispar...|Back to search
#11 Matt Zane
Matt Zane
  • 217 posts
Posted 09 July 2024 - 12:46 PM
Hi Nemo,
If you PM me your details, I've got a fuel pump from my 998 you can have.
The pump was a replacement, and has only been used for about 2-3 hours. I pulled the 998 not long after fitting the new pump.
Give me a shout!
Cheers,
Matt
