Hoping someone can help me here as I am at a loss.
I am trying to finish off a mini built by my son who since emigrated to Australia and left the mini. The problem is that there seems to be something fundamentally wrong with the pre verto clutch set up and I will try and explain.
When the actuating lever is pulled (as if being pushed by the slave cylinder push rod) there is too much travel before the release bearing engages with the diaphragm/pressure plate resulting in about a 20mm gap between the actuating lever and the end of the clutch cover adjusting bolt/lock nut and also the pushrod comes completely out of the slave cylinder. The diaphragm is marked Borg and Beck and the release bearing is what I understand to be the newer type and is marked 7 / W5 / 8
It's as if the release bearing is not deep enough to take up the gap bewtween the plunger seat and the bearing face of the diaphragm, or the plunger not long enough.
Any advice would be greatly appreciated
Best regards - Ken
