Hi all, I,ve got a 1990 Jap spec mini with a Nippon Seiki 2 clock binnacle and I,m considering installing a Smiths analogue temperature gauge and fuel gauge , Is it much of a job to swap over gauges from one make to another? Any advice greatly appreciated.
Smiths Gauges To Replace Nippon Seiki?
Posted 12 July 2024 - 03:53 PM
Posted 12 July 2024 - 04:11 PM
I think you can do it!
Posted 12 July 2024 - 09:20 PM
Posted 13 July 2024 - 02:30 AM
What I,m really unsure about is if there is a voltage regulator fitted to Nippon Seiki instrument cluster,if so where is it situated, is it behind the printed circuit? I,ve read that Smiths water temp and fuel gauges require 10 volts otherwise you get an incorrect reading so does that mean I need to add one of those?
Posted 13 July 2024 - 06:25 AM
Yes they do have one, tucked in with the gauges. It's not external like the Smiths one is.
Posted 13 July 2024 - 07:06 AM
Ok Thanks , So the Nippon Seiki temp and fuel gauges would they be 10 volt too or 12 volt?
Posted 13 July 2024 - 07:25 AM
10 Volt.
Posted 13 July 2024 - 11:27 AM
OK, thanks for the info, i,m getting a bit more in the picture now.
