Good day all,
I have an 88 998cc. I recently started having an issue with my engine just suddenly started running very rich. I’ve gone through the carb (float appears to be working fine), and ignition system, annd timing everything seems fine but no luck correcting the issue. I did a compression check and it appears very low at 90-92 psi across all cylinders. I added a teaspoon of oil and it jumped a couple pounds but still below 95. Based on that I assume the rings at the very least are probably pretty tired. I borescoped the engine, the pistons and cylinder walls look ok at least visually. Budget is tight right now, is it possible I can get away with a hone and rings with that low psi or will I likely need to punch out the block. I know it’s tough to answer without more info, I don’t know the history of the engine but it has just over 50k on the clock, Trying figure out the best option prior to tearing into it.
