Hello,
After a bit of help to find a STD set of piston rings for a 1000cc (998) A-Series. 99H791P
Minispares is my go-to usually, however they don't have anything that suits my pistons.
Pistons are original, dished, 4 rings, top ring is approximately 0.057” thick, the next 2 are about 0.062” thick, and the lower scraper is about 0.123” thick.
The ones Minispares lists has all 3 top rings are the same thickness.
The rings on the pistons currently, the top one looks to be chrome, the next 2 are different - likely cast, and then the scraper is obviously different again.
Picture of piston attached.
Not seen this before either, but there is a slit below the scraper ring, on one side of the piston - whats that for? Its on all of them.
My bores are still round, bottoms still perfectly in spec at 2.543" and the tops are 2.545" for 3 of them, and 1 is 2.546", so still very much in spec for STD if I am not mistaken. I just plan to give a light hone to remove the glaze, and put in new rings, along with a few other things like bearings, seals etc.
Anyone know where I can source suitable rings? I am just having no luck, plus don't really know the best places to look.
I am located in New Zealand, so will have to get them shipped over.
Thanks in advance
