Cooper S speedo help
Posted 20 November 2006 - 07:02 PM
I'm restoring a MK2 Cooper S with its 10'' wheels and I decided to fit a 3.1 final ratio, instead of the original 3.44.
The speedo is calibrated to work with a 3.44 final ration, so how can I make it to read the right speed?
Posted 20 November 2006 - 07:18 PM
Guessworks has a calculator on his clubs website that should help i think. 2 secs wil find it
found it
http://www.rcmoc.org...uff/Ratios.html
Edited by miniboo, 20 November 2006 - 07:19 PM.
Posted 20 November 2006 - 09:42 PM
These are mechanical, inline gearboxes that mount IN the speedometer cable. You'll have to supply the speedometer shop with at least one new cable, and careful measurements of your speedometer error (preferably based on odometer readings). Drive a known, exact, measured distance and report that along with your coresponding odometer reading to the speedometer shop. They'll use that to build a gearbox to match the speedo to your existing drivegears. They aren't cheap but they do work and have been used for years when people have transplanted drivetrains from one car to another.
Picture:
http://www.a1electri...mages/ratio.jpg
Posted 20 November 2006 - 09:46 PM
Think you may also need the time taken lol
Posted 21 November 2006 - 01:07 AM
Posted 21 November 2006 - 03:57 AM
You do not need the time taken, you need the distance you actually drove and the distance as displayed on your odometer. The odometer is hard geared to the drive cable. The needle is subject to calibration errors and it's not what you provide the shop. Providing the speedo shop the two distance measurements allows them to accurately make a gearbox that exactly matches the gearing on your car (both in the transmission and in the gauge). Any subsequent error in the speedometer needle needs to be addressed by gauge re-calibration.
Don't believe me? Call a speedo shop and ask them. As for recalibrating your speedo (Speedy cables or other), you can make an analog needle go anywhere you want. There are only a handful of worm and pinion gears that fit the speedometer odometers. You may not find the combination you're looking for and if you do, it will be very costly. By comparison, the ratio box is an external component that can be changed every time you change your drive combinations without taking the speedo apart.
Posted 21 November 2006 - 08:49 AM
cheapest option i reckon
Posted 21 November 2006 - 09:01 AM
A std mini on 10's with a centre speedo and a 3.44 FD has a worm/pinion ratio of 6/17. if you change the FD to 3.1, then you need to change the worm/pinion ratio to 7/18, or if you go for a 3.2, you'll need a 6/16
Posted 21 November 2006 - 09:52 PM
http://www.speedycables.com/faq8.htm
You'll note that the measurements they ask you to make involve measuring the tyre size and the number of revolutions of the tyres and speedo cable when you go a known distance... not speed.
Posted 21 November 2006 - 10:29 PM
thats what i did when i change the gearbox/wheel sizes on my mini
Posted 21 November 2006 - 10:35 PM
Actually... I meant exactly what I said.
