Csi Dizzy, Which Plugs?
4 replies to this topic
#1 GT Jimmy
GT Jimmy
  • 1,664 posts
  • Local Club: S.U.N.M.C
Posted 29 July 2024 - 12:25 PM
I have a CSI dizzy, I've been running bp6es, but wondering would running a resistor plug benefit the electronics in this dizzy? Cheers
#2 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 29 July 2024 - 01:01 PM
The CSI website says you can use copper ignition leads “In fact, you can / may use copper leads when there is no observable problems” which would lead me to assume the module in the distributor isn’t overly sensitive to interference
https://csi-ignition.com/support/
#3 StefanMini
StefanMini
  • 101 posts
  • Local Club: M.S.C.N
Posted 29 July 2024 - 09:02 PM
With my similar 123 ignition I use the NGK BP6ES spark plugs and don't have problems so far. AC Dodd also recommend to use this spark plugs.
#4 Spider
  • 15,684 posts
Posted 29 July 2024 - 09:49 PM
I ran non-resistor plugs with mine for around 10 years. I did swap over to Resistor Plugs a few years back and found them to be just that wee bit better.
#5 GT Jimmy
GT Jimmy
  • 1,664 posts
Posted 31 July 2024 - 06:45 PM
Thanks for the advice lads. I ended up going with resistor plugs, mainly because they were in it when I had it rolling roaded. Also fitted new arm, cap and some powerspark leads. Glad to say it's 95% there
