Steering Column
Posted 03 August 2024 - 02:53 PM
I've just had a look and the outer column is knocking slightly against the inner column just as it comes through the floor. I've adjusted the column drop bracket and slid the outer column lower towards the clamp amd then nipped it back up. Is there supposed to be a bush in there to stop that movement.
I also tightened up the steering rack u bolts a quarter turn each but I'm conscious of not over doing those.
Posted 03 August 2024 - 02:55 PM
Depends on year. Early had a felt bush.
Posted 03 August 2024 - 04:59 PM
Posted 03 August 2024 - 06:09 PM
Posted 03 August 2024 - 07:40 PM
Posted 03 August 2024 - 09:09 PM
I've just looked up my invoices and I put in a plastic bottom bush. How much slop should there be
With the plastic bush - none, however up to about 20 thou (1/2 mm) might be acceptable.
Posted 03 August 2024 - 09:25 PM
Posted 03 August 2024 - 10:12 PM
You should have an upper plastic bush and a oil soaked felt bush on an 1980 pick up.
