Thermostat Bolts Or Studs
Posted 04 August 2024 - 09:11 PM
Online most mini sites seem to list studs and nuts/washers.
The head is a 12g940b unleaded from a mini spi. Thank you.
Posted 04 August 2024 - 09:21 PM
Edited by Midas Mk1, 04 August 2024 - 09:21 PM.
Posted 04 August 2024 - 09:28 PM
Posted 04 August 2024 - 09:36 PM
Never a fan of tightening a unc thread when you can be tightening a UNF thread.
Posted 04 August 2024 - 10:17 PM
I think there are arguements for and against either fixing method.
If using studs and nuts, corrosion can form between these steel studs and the alluminium thermostat housing making the removal of said housing difficult but this method negates damage to the threads in the cylinder head, but in practice I find that if this corrosion has occured then the steel studs have to be removed anyway for replacement, so they are unscrewed from the head.
By using bolts to secure the housing them the action of unscrewing the bolts can "break" any corrosion between them and the housing and permit the removal of the housing undamaged.
The use of stainless steel fixings and a ceramic grease may help the situation regarding the corrosion between them and the housing and by torqueing these fixings, either bolts or studs should result in no damage to the threads.
Others may have strong arguements for their preference but this is my take on things, the choice is yours.
Posted 04 August 2024 - 11:22 PM
I've always used stainless bolts with duralac on the threads and shafts. They're a low torque, so i'm not fussed about the UNC thread.
Posted 05 August 2024 - 05:02 AM
I prefer bolts here.
If there's corrosion, I've always found there's a better chance of getting the bolt out than with studs.
I'll add that every single time I fit or re-fit the bolts here, I grease them along the shank so there is reduced corrosion.
Posted 05 August 2024 - 07:43 AM
Posted 05 August 2024 - 08:57 AM
Studs. .............. And carefully wrap a little PTFE tape, clockwise round the shanks, after fitting the gasket.
The nuts come undone easily and any aluminium corrosion doesn't get to the steel studs.
Posted 05 August 2024 - 12:32 PM
As Deadsquare above suggests, or a very light smear of copper ease.
Cheers, Steve.
Posted 05 August 2024 - 02:18 PM
Tape or RTV is a good idea on the threads if the hole goes through to the water jacket.
Haven't tried it, but I expect plastic washers, for insulation, would work fine too.
Posted 05 August 2024 - 08:47 PM
