Front Seat Brackets
6 replies to this topic
#1 Whizzbang
Whizzbang
  • 68 posts
Posted 06 August 2024 - 09:55 AM
Why are the 3 available holes for the seats in an ausmini mk1 cooper S square? Are there special bolts for these brackets?
#2 nicklouse
  • 18,998 posts
Posted 06 August 2024 - 10:16 AM
Most likely to allow for the bending tolerance during manufacture. Just think if the holes were the correct size and the bends were not 100% you would not get the bolt through.
#3 scoop-deluxe
scoop-deluxe
  • 63 posts
Posted 06 August 2024 - 10:35 AM
There is a square section under the round bolt head that stops the bolt turning in the bracket. Much like a coach bolt, wing nut retains the end for easy adjustment.
#4 68+86auto
68+86auto
  • 1,344 posts
  • Local Club: Queensland Mini Car Club
Posted 06 August 2024 - 10:37 AM
The correct bolts are coach bolts and had a wing nut so they could be removed by hand.
There's a local here who claims to be the reason they fitted them, I highly doubt it though.
#5 Spider
  • 15,684 posts
Posted 06 August 2024 - 06:51 PM
I thought the earlier UK cars were the same ?
We had these factory fitted seat brackets fitted here in production from roughly 1962-ish to sometime in 1977.
and to save me typing it all out !
The tilt lock appeared around 1972 or 73 to comply with our local ADRs though a similar mechanism was in the UK cars, though I'm not sure from when. Prior to the tilt catch, one could simply tilt the seat anytime they wished - wanted or not !
As Scoop and 68-86 mentioned, there was a Dome headed 1/4" UNF bolt used, that had a square under the head to prevent them from spinning and a diecast wingnut.
Adjusting these was the very first mechanical thing I ever did on a Mini, that was for my Dad back around 1974-ish.
Ben at MinisPlus has the right hardware;-
https://www.minisplu...olt-and-wingnut
If you are looking for originality, the Bolts were painted black.
#6 Whizzbang
Whizzbang
  • 68 posts
Posted 11 August 2024 - 07:29 AM
Thanks all, very helpful
#7 amsgw
amsgw
  • 60 posts
Posted 27 September 2024 - 09:56 PM
Does anyone have a photo of how the seat latch is installed? Mine is a 1981 City, no latches in sight - I just took this as a given as an older car but apparently not, thanks spider for your knowledge! Can't seem to find the part on minispares either?
