Good morning all Bit of a long post. but here we go
Rover Mini Cooper 1.3 MPI
R284 CGT Flame red White roof with factory Webasto.
MoT pass at 25/07/2024 at 57,861 no advisories, current reading 57,867.
Taxed insured good to go. Only issue I can't fathom is overheating. New rad, new fan, temp sensor, all hoses new. Left at idle it boils up, fan not coming on. Have renewed relay to bulkhead. If I connect fan to a slave battery it works.
Help!!!
Major resto history over 8 years
OEM parts used extensively. New front wings and front panel, A panels and flitch panels, complete floor to o/side, 2/3rd floor to n/side, new sills, jacking points and sling plates, complete new heel board, boot floor, rear susp tops, rear valance, closing gussets etc. Professional respray
All seams to new body panels professionally welded in 2023 to MOT standard, paint matched accordingly.
New rear subframe and new trunnion bushes etc. Radius arms refurbished new trumpet cones, new shocks all round. Undersealed and Waxoyled.
All new door, window and boot rubbers inc windscreen infill strip, window lift mechanisms, rubbers and channels. New gutter strip in black, front, wiper arms etc, rear bumpers and grille all in stainless steel. Dashboard pro restored. Original carpets. New soundproofing all round.
Coach lines, bonnet stripes and decals as per original fitted.
Complete new brakes all round inc rear wheel cylinders, shoes, springs, braided hoses, h/brake cables, new brake lines. New front caliper’s, discs and pads, braided hoses, master cylinder overhauled. Track rod ends, wheel bearings and ball joints, CV joints and boots all renewed.
New radiator, hoses, water pump, HT leads, thermostat, temp sensor, new exhaust complete inc cat converter. New clutch master cylinder inc braided hose and slave cylinder, fuel and oil filters, new battery. Fuel tank steam cleaned.
New starter relays, engine management relay unit replaced. Original ECU unit. Wiper motor, wheel boxes and drive spring cleaned and regreased, new wiper park switch.
4 new Falken 165 12 60 tyres. Original minilites in excellent condition.
Webasto sunroof fabric renewed, watertight. Headlining cleaned. Original carpets and upholstery cleaned.
