Replacing Fan Belt
Best Answer GraemeC , 09 August 2024 - 10:59 AM
Yours is worn.  The 10 in the part number signifies it should be 10mm wide.
I don't understand what you mean by not fitting in the pulleys deep enouh to adjust? The belt shouldn't sit too far into the pulleys as it then won't grip as effectively.  The fraction of extra 'length' you will gain by it sitting slightly deeper shouldn't give that much more adjustment.  If you have fitted the new belt and it is around all the pulleys it 'must' adjust, you probably just need a bit of extra leverage to help stretch it slightly.
If the aldjustment has reached its upper limit then sitting deeper into the pulleys would make that worse - essentially the belt is then too long.
Go to the full post
8 replies to this topic
#1 ecky
ecky
    Just On Tickover
  • 8 posts
Posted 09 August 2024 - 10:37 AM
Hi, the fan belt i need replacing is contitech avx 10x813 v belt , i have measured this and  the width is 8mm and the v is 8mm , the new belt is 10mm in width and does not fit in the three pulleys deep enough to adjust. Mini Sprite 1992 1275 ,thanks you.
#2 GraemeC
GraemeC
  • 7,453 posts
Posted 09 August 2024 - 10:59 AM   Best Answer
#3 DeadSquare
DeadSquare
  • 3,218 posts
Posted 09 August 2024 - 11:36 AM
The outer side of any V belt should be proud of the rim of the pulley.
A V belt's grip comes from the wedged sides of the belt.
If the outer side of a V belt is level with the rim of the pulley, the inner side is probably running in the bottom of the pulley and has effectively become a flat belt.
I can't put my hand on my, by now over 100 years old copy of "The Flexible Transmission of Power", but a V belt with the same cross section as a flat belt, has about 80% more grip on the pulley than a flat belt.
#4 ecky
ecky
    Just On Tickover
  • 8 posts
Posted 09 August 2024 - 11:40 AM
Hi, thanks for reply . The belt will not fit around the pulleys , any suggestions on this please
#5 Designer
Designer
  • 650 posts
  • Local Club: LSMOC
Posted 09 August 2024 - 12:39 PM
Hi,
Can you post some pictures so we can see exactly what you are experiencing.
Paddy
#6 weef
weef
  • 511 posts
Posted 09 August 2024 - 12:54 PM
A new belt can be quite tight to fit round the pulleys then once its on its slack and you wonder why it wouldn't fit.
Fit the belt to the water pump and crankshaft pulleys, slacken the alternator bolts and remove the bottom bolt completely.
This gives the maxium travel on the alternator, fit the belt over the alternator pulley and tension with a lever between the engine block and the alternator. Keeping the tension on refit the bottom alternator bolt, and then tension as normal.
Give this a try and I hope it helps.
#7 KTS
KTS
  • 2,483 posts
Posted 09 August 2024 - 01:31 PM
As above, but you will also need to slacken off the nut at the inner (i.e engine) end of the alternator stay to allow the alternator to pivot as far back as it can go.
can't recall if it's possible to fit the stay the wrong way round, but worth checking;  slotted end to the engine, the end with the single hole to the alternator
#8 mad4classics
mad4classics
  • 200 posts
Posted 09 August 2024 - 05:48 PM
As everyone has already said - slacken ALL alternator mountings and adjustments...
Are you replacing like for like 10 x 813 (W x L) ?
Is the current adjustment position right up one end of the slot ?
Maybe you need one of the longer alternatives...
Edited by mad4classics, 09 August 2024 - 05:58 PM.
#9 ecky
ecky
    Just On Tickover
  • 8 posts
Posted 09 August 2024 - 06:29 PM
Hi , Thank You to GRAEME C, DEAD SQUARE , DESIGNER , WEEF , KTS for your input!.
I took the radiator out removed fan on water pump , placed belt around pulleys and replaced fan to water pump , refitted alternator slide , tension and tightened , DONE! . Will keep the old worn belt for emergency replacement. Thanks again  :proud:
