12 Inch Steelies - Oh Nuts
9 replies to this topic
#1 Ethel
  • 26,082 posts
Posted 13 August 2024 - 05:01 PM
Anyone had an 80's era model with the  bolt on fake alloy style hubcaps? The variety with a separate centre cap covering the wheel nuts. Trying to figure out the wheel nut options, I reckon they should be these pieces of rocking horse poo.
What do you  reckon, doctor some NAM9075 sports pack type nuts? The round unhexed bit will ideally be a tad over 10mm long, not including the thickness of the split washer and 16mm in diameter, give or take.
#2 smurfomatic
smurfomatic
  • 461 posts
Posted 13 August 2024 - 05:38 PM
Worth getting in contact with Raceways: https://www.raceways.co.uk/index.html
They were really helpful when trying to source wheel nuts and inserts for my compomotive alloys
#3 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 13 August 2024 - 06:17 PM
Speedshack might be worth a shot too: http://www.speedshac...k/Wheelnuts.htm
#4 Ethel
  • 26,082 posts
Posted 13 August 2024 - 07:00 PM
Ta for the suggestions, I think they may be a tad too bespoke being part tube nut part taper seat.
I think I'll have to do some botching modifying to get what's needed. Thinking the later alloy nut might be designed to also hold on a regular steel wheel if it's carried as a spare, so wondering what I'd be left with if I managed to get off the captive collar bit? If the tube bit it sits on is  a 16mm diameter, give or take and 10mm plus in length I reckon summet could be possible. Plan B would be to get the longest wheel nut possible & turn it down at the pointy end.
#5 1984mini25
1984mini25
  • 8,785 posts
Posted 13 August 2024 - 07:23 PM
Pretty sure they will do just the nuts if you ask nicely enough. https://www.ebay.co....U0AAOSwZsllJWXK
#6 GraemeC
GraemeC
  • 7,440 posts
Posted 14 August 2024 - 08:30 AM
I may have some spares - how many do you need?
#7 68+86auto
68+86auto
  • 1,014 posts
  • Local Club: Queensland Mini Car Club
Posted 14 August 2024 - 12:11 PM
They should be easy to find used as most people replace the steel wheels.
I have those wheels and hubcaps but someone has tried to remove them without removing the wheel nuts so the hubcaps are all broken.
#8 colinf1
colinf1
  • 1,030 posts
Posted 14 August 2024 - 12:23 PM
If GraemeC cant help you, I have some that I can send you
#9 Ethel
  • 26,082 posts
Posted 14 August 2024 - 11:13 PM
Thanks everyone,
I'd need all 16.
#10 GraemeC
GraemeC
  • 7,440 posts
Posted 15 August 2024 - 05:57 AM
I’ll have a root through some tubs and report back
