Instrument Cluster Problems
1 reply to this topic
#1 Trigger01
Trigger01
    Starting My Mini Up
  • 1 posts
Posted 27 August 2024 - 03:27 PM
Hi all.Sorry if this touches other previous discussions but ive scoured through them and tried all sorts but cannot solve the issues. Fuel gauge never works, temp gauge works most of the time, oil pressure light never works, ignition light doesn't work with just ignition on but comes on sometimes after driving for about 15mins or so. All backlighting, speedo and indicator lights work. I've tried shorting tank sender positive to earth (didn't work) I've wired an alternative voltage regulator to back of cluster, fuel gauge worked when removed and triggered by hand,checked all fuses. Sorry for the long read but, any ideas or advice greatly appreciated
#2 Spider
  • 15,201 posts
Posted 27 August 2024 - 06:20 PM
Hi and welcome to the forum.
Firstly, just so we are all sure, what type of Instrument cluster have you go there - centre gauges or off-set in front of the driver ?
Also, what year model is your Mini ?
