1993 1275 Tahiti
3 replies to this topic
#1 Harryhotrod
Harryhotrod
    Starting My Mini Up
  • 2 posts
Posted 29 August 2024 - 06:53 PM
Quick question, my 93 mini tahiti 1275 struggled to get through emissions on its mot,I had to really lean it off.
I believe carb is a HIF38 but exhaust looks aftermarket poss maniflow and rc40 been on a long time , what's your thoughts.
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,374 posts
  • Local Club: Amoc
Posted 29 August 2024 - 07:18 PM
1993 so does this have a cat on the exhaust system?
Also what fuel you running. Supermarket fuels believe it or not are not the best......
#3 Harryhotrod
Harryhotrod
    Starting My Mini Up
  • 2 posts
Posted 30 August 2024 - 07:57 AM
No cat and only use esso super
#4 lsto
lsto
  • 606 posts
Posted 30 August 2024 - 06:57 PM
If you have to adjust the mixture to pass an emissions test then chances are your needle is wrong in your carb.
Contact @ACDodd on here and get him to tune your car, it will be the best money you ever spend on your car. He will run through the ignition and carb and set it all up correctly. He has videos on YouTube if your interested in the oily bits.
Good luck.
