Oil Out Dipstick Hole
Posted 29 August 2024 - 07:53 PM
Posted 29 August 2024 - 08:01 PM
How are you breathers connected to the carb?
Posted 29 August 2024 - 09:02 PM
Posted 29 August 2024 - 09:04 PM
If you have crankcase breathers and they are not blocked, then the oil coming from the dipstick hole is due to there being no seal where the dipstick enters the hole.
It's not unusual and the best cure is to first of all fit an O-ring onto the dipstick, then make up a small bracket from the lower alternator mounting bracket and fit a spring to the dipstick to hold the stick in tightly. I always do this on performance engines and it works every time.
Posted 29 August 2024 - 09:11 PM
Posted 29 August 2024 - 09:45 PM
Okay thanks for suggesting- I was bothered that I’d be trapping pressure causing leaks elsewhere.
No, the dipstick hole is not supposed to be any part of the breather system. The dipstick does need to be sealed with an O-ring or rubber washer.
Posted 30 August 2024 - 12:09 AM
That fitting on the air filter probably doesn't actually have a hole drilled so you may have blocked the breather. Are you sure it was originally connected that way?
Edited by 68+86auto, 30 August 2024 - 12:09 AM.
Posted 30 August 2024 - 04:04 AM
Posted 30 August 2024 - 06:02 AM
That breather pipe should be connected to the appropriate port on the carb, not the air filter box. As previously mentioned, the pipe on the airbox is probably blanked off anyway.
This - Leyland went away from airbox breather connections long before '85. The carb should have a pipe set into the body just beffore the butterfly.
Posted 30 August 2024 - 07:10 AM
Your Mini should have a CCV Crankcase Breather arrangement. When I can get Imgur working again, I'll post a diagram.
Also, how old is the Oil Filler Cap ? There are vented (allowing fresh air in). These do need to be changed periodically.
Posted 30 August 2024 - 09:41 AM
It doesn't need much, the small vacuum pressure from the carb is enough.
Edited by Steam, 30 August 2024 - 09:43 AM.
Posted 30 August 2024 - 11:45 AM
Posted 30 August 2024 - 08:00 PM
Posted 30 August 2024 - 08:17 PM
Alot of people blank off the breather tube in the carb for that very reason, it can change the mixture and cause poor running. You could plumb it in then get the fuelling set up. Or keep it as is and drill the air box. Failing that just put a filter on your breather and just have it open to atmosphere, this would be the easiest option although not the best.
Good luck.
